Выберете то, что вам нужно
Insert an opening pick between the rear case and the plastic rim.
Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
Continue to slide the pick around the edge of the rear case until all clips are released.
Insert an opening pick between the plastic frame and the screen.
Slide the opening pick around the perimeter of the screen.
Use the flat end of the spudger to flip up the press-fit connector attaching the LED to the motherboard.
Remove the LED indicator light by gently pulling upward with nylon-tipped tweezers.
4 участников успешно повторили данное руководство.
Один комментарий
Above article is useful for removing LED Light.
Which LED are we removing - Camera Flash or screen display LED?
How to fit new LED Light?
Please reply. I am facing issues with screen display and flash for camera is also not working
