Введение
Use this guide to replace the motherboard of your Samsung Galaxy Tab 3 10.1.
Выберете то, что вам нужно
Using your plastic opening tools, carefully start to pry apart your Samsung Galaxy Tab 3 10.1 all along the edge. Do this until the back side of the tablet can be removed.
Be careful when inserting the opening tools to avoid damaging the speakers on left and right sides. The picture actually show a dangerous position for the right (small) opening tool.
Gently remove tape over ribbon cable connectors and set it to the side. Using the opening tools, gently lift the connector latches to disconnect the ribbon cables.
Using a Phillips #00 screwdriver, remove the ten screws securing the battery to the motherboard.
Pull back the ribbon cables, lift up the original battery, and disconnect the battery by exerting upward pressure from beneath the battery.
Using the plastic opening tool, pry on the edge of the motherboard lifting it up. Keeping one side lifted, insert the tip of your other removal tool and continue prying. Work the edges of the motherboard, moving the tips of the tools away from each other until the motherboard is free.
18 участников успешно повторили данное руководство.
5 Комментариев
Hello, I recently purchased a motherboard for a galaxy tab 3 10.1 16GB. I recieved it today and everything looked great. I went to install it and it does not quite fit. The right side of it overlaps just a bit raising the board above where it should be seated. I went ahead and attached all the cables the connector on the far right side of the board is in a slightly diffdrent location but with a slight bend in the ribbon cable it snapped into place, I could only get one screw to reach the threaded hole from where the board is raised due to the over size. I attached the battery and screwed the bottom side thats is away from the board and turned it on and. Everytging works fine except the camera and home button and the back wont fully snap on because the of the raised board. Not sure what to do or how to make it fit properly. Please help
I also cannot get ahold of anybody in customer serice through phone cann or email so I guess ill rely on the people to help me since ifixit obviously does not care about its customers6
Samsung you have a legal commitment to your customers for after sales service, its not all about sales and profits.
