Отремонтируйте ваше устройство
Обучение ремонту
Магазин
  1. Insert an opening pick between the rear case and the plastic rim. You may need to add multiple picks to detach the clips.
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Lift the case up to remove it. Lift the case up to remove it.
    • Lift the case up to remove it.
  3. Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors. Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors. Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
    • Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
  4. Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable. Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
    • Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
  5. Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors. Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors. Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
    • Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
  6. Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
    • Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
  7. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  8. Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard. Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
    • Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
  9. Lift with a nylon spudger to remove the battery. Lift with a nylon spudger to remove the battery.
    • Lift with a nylon spudger to remove the battery.
  10. Insert an opening pick between the plastic frame and the screen. Slide the opening pick around the perimeter of the screen.
    • Insert an opening pick between the plastic frame and the screen.
    • Slide the opening pick around the perimeter of the screen.
    • You will hear clicking noises as each plastic clip is released from the display chassis.
  11. Lift the plastic frame to remove.
    • Lift the plastic frame to remove.
    • Avoid the three delicate ribbon cables.
  12. Use a Phillips #000 screwdriver to remove the 3mm screw attaching the motherboard to the display chassis.
    • Use a Phillips #000 screwdriver to remove the 3mm screw attaching the motherboard to the display chassis.
  13. Use a nylon spudger to flip up the eight press-fit connectors from the motherboard. The vibration motor is missing from these photos. The vibration motor is missing from these photos.
    • Use a nylon spudger to flip up the eight press-fit connectors from the motherboard.
    • The vibration motor is missing from these photos.
  14. Use nylon-tipped tweezers to remove the motherboard. Use nylon-tipped tweezers to remove the motherboard.
    • Use nylon-tipped tweezers to remove the motherboard.
  15. Using the pointed end of a nylon spudger, pry upwards between the screen chassis and the auxiliary port. The speaker is permanently connected to the auxiliary port and will need to be removed from the device as a single unit.
    • Using the pointed end of a nylon spudger, pry upwards between the screen chassis and the auxiliary port.
    • The speaker is permanently connected to the auxiliary port and will need to be removed from the device as a single unit.
  16. Use the flat end of a spudger to pry upwards between the speaker and the display chassis. Remove the speaker and auxiliary port assembly.
    • Use the flat end of a spudger to pry upwards between the speaker and the display chassis.
    • Remove the speaker and auxiliary port assembly.
  17. Use the pointed end of a spudger to pry upwards between the other speaker unit and the display chassis. Use the pointed end of a spudger to pry upwards between the other speaker unit and the display chassis.
    • Use the pointed end of a spudger to pry upwards between the other speaker unit and the display chassis.
Заключение
Corey Brown
Участник с: 24.06.2016
6 516 Репутация
Автор 11 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 1,018
