Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, White Backing: шаг 1, изображение 1 из 3 Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, White Backing: шаг 1, изображение 2 из 3 Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, White Backing: шаг 1, изображение 3 из 3
    • To begin working on your repair, turn your device over and open the micro SD slot, as shown in the first picture.
    • Using the flat part of the spudger, begin pushing it between the white backing and the SD slot. Continue to pry off the white backing until you hear several clicks and see the white backing lift up, as shown in the second picture.
    • Continue to pry off the white backing around the device, as shown in the third picture.
  2. Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement: шаг 2, изображение 1 из 1
    • Once the backing has been pried off all around the device, remove the white backing.
  3. Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, Silver Siding: шаг 3, изображение 1 из 3 Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, Silver Siding: шаг 3, изображение 2 из 3 Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, Silver Siding: шаг 3, изображение 3 из 3
    • To remove the silver siding, begin by pushing the spudger between the frame and the screen, as shown in the first picture.
    • Do this until you see the silver siding begin to lift up. Continue doing this around the edges of the device, as shown in the second picture.
    • Once you silver siding is loose all around the device, remove it carefully with your hand as shown in the third picture.
Заключение
22 участников успешно повторили данное руководство.
Andrea Flores
Участник с: 10/09/14
1 516 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 14-30, Maness Fall 2014 Участник Cal Poly, Team 14-30, Maness Fall 2014
CPSU-MANESS-F14S14G30
4 членов
Автор 18 руководств
7 Комментариев
Awesome, I was able to use this guide to easily replace the integrated battery in my seven inch version of the Galaxy Tab 3!
segin2005 - Ответить
Hello,
I cannot understand why my tablet galaxy T211 3 7.0 3G can't turn on anymore... The screen is black, i don't know is happening and all the "internet tricks" power off- sounds etc doesn't function do you have any solution?
Thank u
alizeescolas - Ответить
It would be easy the said. It will only take five minutes they said. Yeah right you lying ass ##&&%. It took me 2 and a half hours to get off and it was NOT easy. Not to mention the tools I was using to get it off chipped and cracked part of the white back cover.
Queen Valencia - Ответить
Never buying a Galaxy Tab again!
RoRoTX Wills - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 24
За всё время: 111,918
