Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This disassembling guide is useful for many repair guides involving the device such as battery replacement, camera replacement etc..
Запчасти
Детали не указаны.
  1. To begin working on your repair, turn your device over and open the micro SD slot, as shown in the first picture. Using the flat part of the spudger, begin pushing it between the white backing and the SD slot. Continue to pry off the white backing until you hear several clicks and see the white backing lift up, as shown in the second picture. Continue to pry off the white backing around the device, as shown in the third picture.
    • To begin working on your repair, turn your device over and open the micro SD slot, as shown in the first picture.
    • Using the flat part of the spudger, begin pushing it between the white backing and the SD slot. Continue to pry off the white backing until you hear several clicks and see the white backing lift up, as shown in the second picture.
    • Continue to pry off the white backing around the device, as shown in the third picture.
  2. Once the backing has been pried off all around the device, remove the white backing.
    • Once the backing has been pried off all around the device, remove the white backing.
  3. To remove the silver siding, begin by pushing the spudger between the frame and the screen, as shown in the first picture. Do this until you see the silver siding begin to lift up. Continue doing this around the edges of the device, as shown in the second picture. Once you silver siding is loose all around the device, remove it carefully with your hand as shown in the third picture.
    • To remove the silver siding, begin by pushing the spudger between the frame and the screen, as shown in the first picture.
    • Do this until you see the silver siding begin to lift up. Continue doing this around the edges of the device, as shown in the second picture.
    • Once you silver siding is loose all around the device, remove it carefully with your hand as shown in the third picture.
Заключение
22 участников успешно повторили данное руководство.
Andrea Flores
Участник с: 09.10.2014
1 501 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 14-30, Maness Fall 2014 Участник Cal Poly, Team 14-30, Maness Fall 2014
CPSU-MANESS-F14S14G30
4 членов
Автор 18 руководств
Комментариев: 7
i need the back panel
Nithyanand 333 - Ответить
Awesome, I was able to use this guide to easily replace the integrated battery in my seven inch version of the Galaxy Tab 3!
segin2005 - Ответить
Hello,
I cannot understand why my tablet galaxy T211 3 7.0 3G can't turn on anymore... The screen is black, i don't know is happening and all the "internet tricks" power off- sounds etc doesn't function do you have any solution?
Thank u
alizeescolas - Ответить
It would be easy the said. It will only take five minutes they said. Yeah right you lying ass ##&&%. It took me 2 and a half hours to get off and it was NOT easy. Not to mention the tools I was using to get it off chipped and cracked part of the white back cover.
Queen Valencia - Ответить
Never buying a Galaxy Tab again!
RoRoTX Wills - Ответить
Beautiful! I only wish I had found this before I took the back cover off.
Stephen Willie - Ответить
I had a hard time getting the back cover back on, it would not click in, in one place. The reason the device does not turn on is because the cover is not providing the connection it needs. Press down where the on switch is. That worked for me.
Marlene B - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 18
За последние 7 дней: 111
За последние 30 дней: 369
За всё время: 108,261
