Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Before taking apart the tablet, be sure to buy the replacement battery. You can find batteries online by searching, “Samsung Galaxy Tablet 4 10.1 battery.” The battery used in this guide is the 6800 mAh 3.7V.
Below is a link to purchase the recommended battery:
https://www.amazon.com/Samsung-GALAXY-Ta...
  1. Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off. Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Peel off the green tape that covers the connectors for the three black strips.
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Use a Phillips #00  screwdriver to remove the four 3.2mm  screws.
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
    Take note of the red warning comment! Very easy to pull up the connector off the board!!!
    Unfortunately I just that because I didn’t hold down the connectors with tweezers (or something) and then botched an attempted reflow of the solder, costing even more time and money! :(
    Ashley Lahm - Ответить
  5. Use the nylon spudger to remove the battery by prying up on the edges.
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Once the battery is loose,  lift it out of the device.
    • Once the battery is loose, lift it out of the device.
    I’m new to working on these devices, but I am wondering why the battery is removed? Is that necessary for this repair? Thanks!
    Tuvy Guss - Ответить
    Better disconnect battery before any repairs, therefore reducing the possibility of a short-circuit which could destroy the motherboard.
    Tian Lai Li - Ответить
    Isolation tape can also be placed over the connection after disconnecting to prevent any accidental short-circuit mishaps, thus reducing the need to remove the battery.
    Cheers Wayne
    Wayne Lyell - Ответить
Заключение
42 участников успешно повторили данное руководство.
Samantha Gunzl
Участник с: 30.09.2016
539 Репутация
1 руководство автора
Команда
Cal Poly, Team 18-1, Forte Fall 2016 Участник Cal Poly, Team 18-1, Forte Fall 2016
CPSU-FORTE-F16S18G1
5 членов
Автор 3 руководств
Комментариев: 5
Well, I know what I did wrong. I thought I was super careful, but I damaged the black connector. (Please pay extra attention to the red warning area in Gunzl’s instructions.) It separates from the board extremely easy. My husband was worried about my taking on this task. I know what I did wrong, but that doesn’t help the fact that I will be purchasing another tablet for him. I’m not sure I will purchase another Samsung, but perhaps all the tablets has such fragile inner workings.
Racquel Naylor - Ответить
Don’t worry, you’re not the only one! :(
Ashley Lahm -
Thank you! Will try this.
affriedl - Ответить
the battery on this tablet is terrible, once i get the parts, your guide will come in handy.
kcole - Ответить
Regarding Step 4, Take note of the red warning comment! Very easy to pull up the connector off the board!!!
Добавить комментарий
Просмотр статистики:
За последние 24часов: 28
За последние 7 дней: 123
За последние 30 дней: 574
За всё время: 37,861
