Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Replacement guide for the micro USB charging port on a Samsung Galaxy Tab 4 10.1 android tablet.
The battery only needs to be disconnected—skip steps 3, 5, and 6.
  1. Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off. Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Peel off the green tape that covers the connectors for the three black strips.
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Use a Phillips #00  screwdriver to remove the four 3.2mm  screws.
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  5. Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
  6. Use the nylon spudger to remove the battery by prying up on the edges.
    • Use the nylon spudger to remove the battery by prying up on the edges.
  7. Once the battery is loose,  lift it out of the device.
    • Once the battery is loose, lift it out of the device.
  8. Remove the two 2.7mm Phillips #00 screws from the micro USB port. Remove the micro USB retaining bracket.
    • Remove the two 2.7mm Phillips #00 screws from the micro USB port.
    • Remove the micro USB retaining bracket.
  9. Use the flat end of a spudger to disconnect the micro USB port. Remove the micro USB port.
    • Use the flat end of a spudger to disconnect the micro USB port.
    • Remove the micro USB port.
Заключение
6 участников успешно повторили данное руководство.
Blake Klein
Участник с: 29.01.2017
55 102 Репутация
Автор 49 руководств
Комментариев: 2
Thank you so much for simplifying this guide for us novices. I have tried watching two videos where they assume I already have some Samsung repair knowledge. I feel confident I will be able to get the tablet up and charging in no time.
Stacie Harper - Ответить
There is no need to remove the battery, only detach the power connector, cheers!
Bartosz Kaczynski - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 20
За последние 30 дней: 102
За всё время: 3,880
