Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Battery: шаг 1, изображение 1 из 2 Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Battery: шаг 1, изображение 2 из 2
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: шаг 2, изображение 1 из 1
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: шаг 3, изображение 1 из 1
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: шаг 4, изображение 1 из 1
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
    Take note of the red warning comment! Very easy to pull up the connector off the board!!!
    Unfortunately I just that because I didn’t hold down the connectors with tweezers (or something) and then botched an attempted reflow of the solder, costing even more time and money! :(
    Ashley Lahm - Ответить
  5. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: шаг 5, изображение 1 из 1
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: шаг 6, изображение 1 из 1
    • Once the battery is loose, lift it out of the device.
    I’m new to working on these devices, but I am wondering why the battery is removed? Is that necessary for this repair? Thanks!
    Tuvy Guss - Ответить
    Better disconnect battery before any repairs, therefore reducing the possibility of a short-circuit which could destroy the motherboard.
    Tian Lai Li - Ответить
    Isolation tape can also be placed over the connection after disconnecting to prevent any accidental short-circuit mishaps, thus reducing the need to remove the battery.
    Cheers Wayne
    Wayne Lyell - Ответить
  7. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Micro USB Port: шаг 7, изображение 1 из 2 Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Micro USB Port: шаг 7, изображение 2 из 2
    • Remove the two 2.7mm Phillips #00 screws from the micro USB port.
    • Remove the micro USB retaining bracket.
  8. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: шаг 8, изображение 1 из 2 Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: шаг 8, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the micro USB port.
    • Remove the micro USB port.
Заключение
12 участников успешно повторили данное руководство.
Blake Klein
Участник с: 01/29/17
70 531 Репутация
Автор 50 руководств
2 Комментариев
Thank you so much for simplifying this guide for us novices. I have tried watching two videos where they assume I already have some Samsung repair knowledge. I feel confident I will be able to get the tablet up and charging in no time.
Stacie Harper - Ответить
There is no need to remove the battery, only detach the power connector, cheers!
Bartosz Kaczynski - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 33
За всё время: 7,024
