Введение
Replacement guide for the motherboard on a Samsung Galaxy Tab 4 10.1 android tablet.
Выберете то, что вам нужно
Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
Peel off the green tape that covers the connectors for the three black strips.
Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
Инструмент, используемый на этом этапе:Tweezers$4.99
Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
Use the flat end of a spudger to pry up and disconnect the five press-fit connectors from the motherboard.
8 участников успешно повторили данное руководство.
