Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement, Battery: шаг 1, изображение 1 из 2 Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement, Battery: шаг 1, изображение 2 из 2
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement: шаг 2, изображение 1 из 1
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement: шаг 3, изображение 1 из 1
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement: шаг 4, изображение 1 из 1
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
  5. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement: шаг 5, изображение 1 из 1
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement: шаг 6, изображение 1 из 1
    • Once the battery is loose, lift it out of the device.
  7. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement, Power and Volume Button: шаг 7, изображение 1 из 2 Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement, Power and Volume Button: шаг 7, изображение 2 из 2
    • Pry up and disconnect the power and volume button press-fit connector with the flat end of a spudger.
  8. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement: шаг 8, изображение 1 из 1
    • Remove the power and volume button ribbon cable.
Заключение
4 участников успешно повторили данное руководство.
Blake Klein
Участник с: 01/29/17
70 531 Репутация
Автор 50 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 21
За всё время: 3,639
