Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide will provide step-by-step instructions on how to replace the battery of your Samsung Galaxy Tab 4 7.0. After replacing your tablet battery, it would be wise to recycle the battery at a local battery store or electronics retail center.
Видео обзор
  1. Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing. Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Carefully separate the rear housing from the front panel assembly.
    • Carefully separate the rear housing from the front panel assembly.
  3. You do not need to remove the motherboard in order to remove the battery as the photos may indicate. Work the spudger underneath the battery as shown and pry the battery away from the phone case. The battery is attached to the case with adhesive, so a bit of force is required during removal.
    • You do not need to remove the motherboard in order to remove the battery as the photos may indicate.
    • Work the spudger underneath the battery as shown and pry the battery away from the phone case.
    • The battery is attached to the case with adhesive, so a bit of force is required during removal.
Заключение
28 участников успешно повторили данное руководство.
Edgard R Baladron
Участник с: 31.08.2015
429 Репутация
1 руководство автора
Команда
USF Tampa, Team 1-3, Remmell Fall 2015 Участник USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 членов
Автор 12 руководств
Комментариев: 3
This is for a cell phone, not a tablet. Why?
ckmjunk - Ответить
it is the tablet
sourcandysaiyan -
OH! its so easy!! woohoo, ordering battery now!
sourcandysaiyan - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 23
За последние 30 дней: 78
За всё время: 23,823
