Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement, Rear Case: шаг 1, изображение 1 из 3 Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement, Rear Case: шаг 1, изображение 2 из 3 Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement, Rear Case: шаг 1, изображение 3 из 3
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
  2. Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: шаг 2, изображение 1 из 2 Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: шаг 2, изображение 2 из 2
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: шаг 3, изображение 1 из 2 Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: шаг 3, изображение 2 из 2
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
  4. Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement, Rear Facing Camera: шаг 4, изображение 1 из 2 Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement, Rear Facing Camera: шаг 4, изображение 2 из 2
    • The back camera will be located near the top of the tablet in the center above the battery.
    • Carefully insert the flat end of the blue plastic opening tool under the metal rectangular end of the back camera’s cable connector.
  5. Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: шаг 5, изображение 1 из 1
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the back camera’s metallic rectangular connector from its socket on the logic board.
  6. Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: шаг 6, изображение 1 из 2 Samsung Galaxy Tab 4 8.0 Verizon Rear Facing Camera Replacement: шаг 6, изображение 2 из 2
    • Squeeze the metallic rectangular piece with the tweezers to gently lift it from it's pit.
Заключение
2 участников успешно повторили данное руководство.
Yuly Flores
Участник с: 09/14/15
747 Репутация
1 руководство автора
Команда
CSU Fullerton, Team 1-3, Bruce Fall 2015 Участник CSU Fullerton, Team 1-3, Bruce Fall 2015
CSUF-BRUCE-F15S1G3
4 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 914
