Samsung Galaxy Tab 4 8.0 Wi-Fi Rear Case Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Tab 4 8.0 Wi-Fi Rear Case Replacement, Rear Case: шаг 1, изображение 1 из 1
    • Before you being the replacement process, make sure the tablet is completely powered off.
    • Gently insert the plastic opening tool between the metal rim and the back plastic casing at the bottom of the tablet and pry the back casing away from the device. Continue to separate the back panel of the device from the front assembly.
    • Right-handed users will probably be more comfortable prying in a clockwise movement, while left-handed users will feel more comfortable doing a counter clockwise movement.
    • When taking off the rear case there will be periodic clicking noises. Do not worry about those noises. They are just the rear case being disconnected.
    • Be careful not to use too much force as the plastic clips can easily be broken.
  2. Samsung Galaxy Tab 4 8.0 Wi-Fi Rear Case Replacement: шаг 2, изображение 1 из 1
    • Place the tablet screen down on a clean surface.
    • Grasp the back panel and lift it from the device.
Заключение
3 участников успешно повторили данное руководство.
Cameron Morrow
Участник с: 04/14/16
384 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 25-3, Maness Spring 2016 Участник Cal Poly, Team 25-3, Maness Spring 2016
CPSU-MANESS-S16S25G3
4 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 9
За последние 30 дней: 16
За всё время: 627
