Введение
In this guide you will learn how to successfully pry off the rear case in order to access all the inner tablet components.
Выберете то, что вам нужно
Gently insert the plastic opening tool between the metal rim and the back plastic casing at the bottom of the tablet and pry the back casing away from the device. Continue to separate the back panel of the device from the front assembly.
Place the tablet screen down on a clean surface.
Grasp the back panel and lift it from the device.
3 участников успешно повторили данное руководство.
