Введение
This guide will show you how to remove and replace the rear facing camera on the Samsung Galaxy Tab 4 8.0 Wi-Fi.
Выберете то, что вам нужно
Gently insert the plastic opening tool between the metal rim and the back plastic casing at the bottom of the tablet and pry the back casing away from the device. Continue to separate the back panel of the device from the front assembly.
Place the tablet screen down on a clean surface.
Grasp the back panel and lift it from the device.
The rear facing camera will be located just to the right and below the front facing camera, near the top and center of the motherboard.
Slide the flat end of the blue plastic opening tool underneath the rectangular metal connector of the rear facing camera.
Apply slight pressure outwards until the camera's metal connector pops from its socket on the motherboard.
Еще один человек закончил это руководство.
