Введение
This guide will teach the reader how to replace the audio jack of a Samsung Galaxy Tab 7.0 Sprint. This will require removing other parts of the device to reach the audio jack.
Выберете то, что вам нужно
Fully power off the device.
Disconnect and remove any cables that are connected to the device (i.e. chargers or headphones).
Place the device on a flat, stable, and clean surface.
Remove the plastic tabs on the bottom of the device using the metal spudger, as shown in the pictures.
Wedge a plastic opening tool between the front and back panel, on the bottom right corner.
Slowly push the tool down to make a small gap between the front panel and the back panel.
Holding the tool steady, run the tool along the bottom part of the device from right to left. This will make the gap between the front panel and the back panel bigger.
Leave the previously used tool wedged in the device.
Insert another plastic opening tool into the bottom of the left side, as shown.
Using a similar procedure to the last step, run the tool along the side and widen the front panel-back panel gap. This time, run the device from bottom to top.
Repeat this process for the right side of the device, starting at the bottom of the right side.
Place the front panel on the table, with the battery facing up.
Find the small screw that is holding the battery to the motherboard, and unscrew it using the Phillips #00 Screwdriver.
Lift the bottom part of the battery.
Use a plastic opening tool to remove the battery connector from its place on the motherboard. Make sure to pull it straight up.
With the plastic opening tool, disconnect the following 5 connectors:
Headphone jack/microphone cable
Volume control cable
Touchscreen cable
Control button LED cable
Display data cable
Use the Phillips #00 screwdriver to remove the seven screws holding down the motherboard.
Carefully lift the motherboard away from the rear panel.
Using the Phillips #00 screwdriver, unscrew the panel that secures the audio jack to the rear panel.
After lifting the audio jack off the adhesive, remove it from the device.
To reassemble your device, follow these instructions in reverse order. Make sure all parts are aligned properly before attempting to put them back together.
