Введение
This guide will walk you through the process of replacing a malfunctioning charging port on a Samsung Galaxy Tab 8.9.
Выберете то, что вам нужно
Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
Slide the second plastic opening tool along the edge of the device to separate the back cover.
Insert a spudger under the orange tab.
Pry open the tab to disconnect the black flexible ribbon cable from the motherboard.
Slide out the yellow flexible ribbon cable to disconnect it from the motherboard.
Using a Phillips #00 screwdriver, unscrew the 4 screws (3mm) that are holding the charger port and speaker support.
