Запчасти
Никакие детали не требуются.
  1. Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
    • Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
  2. Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
    • Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
  3. Slide the second plastic opening tool along the edge of the device to separate the back cover.
    • Slide the second plastic opening tool along the edge of the device to separate the back cover.
  4. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Using your hands, remove the back cover.
    • Using your hands, remove the back cover.
  6. Camera can be found near the top center of device.
    • Camera can be found near the top center of device.
  7. Using Spudger, lift connector from mother board Using Spudger, lift connector from mother board
    • Using Spudger, lift connector from mother board
  8. Lift camera and remove from device. Lift camera and remove from device. Lift camera and remove from device.
    • Lift camera and remove from device.
Заключение
2 участников успешно повторили данное руководство.
Aleezee True
Участник с: 30.09.2014
520 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 11-4, Blackwell Fall 2014 Member of USF Tampa, Team 11-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G4
4 членов
Автор 10 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 3
За всё время: 280
