Введение
This guide will walk you through the process of replacing a broken, frozen, or unresponsive display screen on a Samsung Galaxy Tab 8.9.
Выберете то, что вам нужно
Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
Slide the second plastic opening tool along the edge of the device to separate the back cover.
Slide out the yellow flexible ribbon cable to disconnect it from the motherboard.
2 участников успешно повторили данное руководство.
