Samsung Galaxy Tab A (2019) Screen Replacement
Выберете то, что вам нужно
Видеоинструкции
Заключение
17 участников успешно повторили данное руководство.
Nick Myers
Участник с: 04/15/18
3 470 Репутация
Автор 23 руководств
9 Комментариев
si on a pas conserver le pcb qu’il enlève de l’écran cassé on peux le racheter ou?
Yacine Chennoufi - Ответить
How do you heat up the screen to loosen the glue? Heat gun? Blow dryer? How do you keep from damaging it from getting too hot? Thanks :)
Justin Shields - Ответить
Use a heat gun it will help that’s what I would do
nicholaswiding -
I tried this with a hairdryer. While there are probably options that work better, it still helped a lot. I am too much of a coward to use a heat gun, as I don't want to fry it, so I used my wifes hair dryer to the point where the tablet was very hot to the touch around the edge of the screen.
Kristian Jarmund -
Best and safest way to heat up a device to remove screen is with a heating mat………. i set mine at 75deg
Alan Sears - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 10
За последние 7 дней: 67
За последние 30 дней: 259
За всё время: 14,007
