Введение
During all steps, handle all components with care as they are delicate electronic components.
Выберете то, что вам нужно
Using the plastic opening tool, starting at any corner on the tablet, insert the tool between the back panel and the front panel.
Slide tool around the tablet to unlock the panels from one another.
Carefully remove the back panel from the front panel.
The inner components of the tablet will now be exposed.
Using tweezers, at the end of the gold wire, gently lift the black tab locking the wire connecting the camera to the motherboard.
Pull the wire from the connector, disconnecting the camera from the device entirely.
3 участников успешно повторили данное руководство.
