  1. Этот шаг не переведен. Помогите перевести
    Make sure the device is turned off before attempting to disassemble it.
    • Make sure the device is turned off before attempting to disassemble it.
    • At the top portion of the memory card slot, use the small metal spudger to create separation between the back cover and the rest of the device.
    • The small metal spudger is only used to create separation between the back cover and the rest of the device, not to remove the back cover.
    • If possible, try to use a normal nylon spudger to separate the back cover, as it is much softer and less likely to mar/scratch the device.
  2. Этот шаг не переведен. Помогите перевести
    Use the intermediate metal spudger in place of the small metal spudger to remove the back cover. This is done by sliding the intermediate metal spudger around the perimeter of the device, beginning at the top portion of the memory card slot. The second picture shows the internal portion of the device once the back cover is removed.
    • Use the intermediate metal spudger in place of the small metal spudger to remove the back cover. This is done by sliding the intermediate metal spudger around the perimeter of the device, beginning at the top portion of the memory card slot.
    • The second picture shows the internal portion of the device once the back cover is removed.
  3. Этот шаг не переведен. Помогите перевести
    Disconnect the electrical connector from the motherboard using the bent precision tweezers.
    • Disconnect the electrical connector from the motherboard using the bent precision tweezers.
    • Avoid touching the motherboard with the tweezers. Metal tools such as the tweezers can scratch the motherboard and potentially cause damage.
  4. Этот шаг не переведен. Помогите перевести
    Use the flat end of the plastic spudger to pry the battery apart from the rest of the device. An alternative method is to loosen the battery using the plastic spudger, and then to remove the battery by pulling on the paper tab that says "Pull (Hands Only)." Once the back cover and battery are removed, the device should look like as illustrated in the second picture.
    • Use the flat end of the plastic spudger to pry the battery apart from the rest of the device.
    • An alternative method is to loosen the battery using the plastic spudger, and then to remove the battery by pulling on the paper tab that says "Pull (Hands Only)."
    • Once the back cover and battery are removed, the device should look like as illustrated in the second picture.
  5. Этот шаг не переведен. Помогите перевести
    Use a spudger to lift up and release the press-fit display cable connector from the motherboard. Use a spudger to lift up and release the press-fit display cable connector from the motherboard.
    • Use a spudger to lift up and release the press-fit display cable connector from the motherboard.
  6. Этот шаг не переведен. Помогите перевести
    Use a spudger to lift up and release the ZIF connector; gently pull the rear facing camera ribbon cable free. Use a pair of tweezers to gently secure the camera and lift it out of the frame.
    • Use a spudger to lift up and release the ZIF connector; gently pull the rear facing camera ribbon cable free.
    • Use a pair of tweezers to gently secure the camera and lift it out of the frame.
    • If you're unable to secure the camera with tweezers, slide an opening pick between the frame and the camera and lift the camera out.
  7. Этот шаг не переведен. Помогите перевести
    Use a spudger to flip the front-facing camera ZIF connector up; gently pull the ribbon cable free.
    • Use a spudger to flip the front-facing camera ZIF connector up; gently pull the ribbon cable free.
    • Use tweezers to gently remove the front facing camera from the frame.
  8. Этот шаг не переведен. Помогите перевести
    Use the flat end of a spudger to lift up and disconnect the LCD screen press-fit connector.
    • Use the flat end of a spudger to lift up and disconnect the LCD screen press-fit connector.
  9. Этот шаг не переведен. Помогите перевести
    Use the flat end of a spudger to lift up and disconnect the 3.5mm headset jack press-fit connector.
    • Use the flat end of a spudger to lift up and disconnect the 3.5mm headset jack press-fit connector.
  10. Этот шаг не переведен. Помогите перевести
    Use a PH000 screwdriver to remove the two 3 mm screws that connect the USB port shield to the midframe.
    • Use a PH000 screwdriver to remove the two 3 mm screws that connect the USB port shield to the midframe.
  11. Этот шаг не переведен. Помогите перевести
    Use a PH000 screwdriver to remove the two 3 mm screws on the left side of the motherboard. Use a PH000 screwdriver to remove the two 3 mm screws on the left side of the motherboard.
    • Use a PH000 screwdriver to remove the two 3 mm screws on the left side of the motherboard.
  12. Этот шаг не переведен. Помогите перевести
    Lift the motherboard free from the power and volume button side. You may use a spudger to assist in gently lifting the motherboard up from the button side. A small plastic bracket secures the motherboard to the frame; lift the motherboard from the power and volume button side first, and slide away from the bracket.
    • Lift the motherboard free from the power and volume button side.
    • You may use a spudger to assist in gently lifting the motherboard up from the button side.
    • A small plastic bracket secures the motherboard to the frame; lift the motherboard from the power and volume button side first, and slide away from the bracket.
Финишная черта
10 участников успешно повторили данное руководство.
Richard Suovanen
Участник с: 07.02.2017
22 022 Репутация
Автор 10 руководств
Комментариев: 3
Where is the rest of this guide? Just stops after removing motherboard :[
chrischevrier - Ответить
It appears that it is intended to remove all parts from the case (battery and motherboard) and install them in a new body with a good screen attached.
Ben D -
After removing the motherboard, I continued with disassembly by following the iFixit guide for the Digitizer removal.
( Samsung Galaxy Tab A Digitizer Replacement )
After removing the glass/digitizer, I was able to remove the LCD relatively easy by pushing it through the gaps on the back end of the frame. It appeared to not have any adhesive holding it in place. I was replacing the LCD and the digitizer in my case so I was I bit more careless with the removal of those components. I did place a bit of adhesive on the new LCD replacement and everything fit back snuggly.
Uriel Garcia -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 14
За последние 7 дней: 47
За последние 30 дней: 212
За всё время: 8,066
