Введение
Bring new and uninterrupted life back to your beaten and dead Samsung Galaxy Tab A 9.7 through the replacement of the battery inside the device.
Выберете то, что вам нужно
Insert a metal spudger between the back case and the screen of the device.
Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
Remove the eleven #000 Phillips 2.8mm screws that hold the battery in place.
Place one hand on the battery and grasp the outer edge of the device with the other hand.
Flip the device over so that the battery falls over and onto your hand.
Pull the battery out until it is only connected to the device by the black, yellow, and red connectors.
Hold the battery and grip the wires with your thumb and finger.
Pull the wires away from the device to remove the white connector from the black socket.
Lift the battery away from the device.
13 участников успешно повторили данное руководство.
