Samsung Galaxy Tab A 9.7 Display Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Tab A 9.7 Display Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Samsung Galaxy Tab A 9.7 Display Replacement, Battery: шаг 2, изображение 1 из 2 Samsung Galaxy Tab A 9.7 Display Replacement, Battery: шаг 2, изображение 2 из 2
    • Remove the eleven #000 Phillips 2.8mm screws that hold the battery in place.
  3. Samsung Galaxy Tab A 9.7 Display Replacement: шаг 3, изображение 1 из 2 Samsung Galaxy Tab A 9.7 Display Replacement: шаг 3, изображение 2 из 2
    • Place one hand on the battery and grasp the outer edge of the device with the other hand.
    • Flip the device over so that the battery falls over and onto your hand.
  4. Samsung Galaxy Tab A 9.7 Display Replacement: шаг 4, изображение 1 из 2 Samsung Galaxy Tab A 9.7 Display Replacement: шаг 4, изображение 2 из 2
    • Pull the battery out until it is only connected to the device by the black, yellow, and red connectors.
  5. Samsung Galaxy Tab A 9.7 Display Replacement: шаг 5, изображение 1 из 2 Samsung Galaxy Tab A 9.7 Display Replacement: шаг 5, изображение 2 из 2
    • Hold the battery and grip the wires with your thumb and finger.
    • Pull the wires away from the device to remove the white connector from the black socket.
    • Lift the battery away from the device.
  6. Samsung Galaxy Tab A 9.7 Display Replacement, Display: шаг 6, изображение 1 из 1
    • Gently remove the tape covering the screen ribbon cable, located at the top of the devise.
    • With the plastic spudger, disconnect the ribbon cable from the motherboard, located at the middle of the device.
  7. Samsung Galaxy Tab A 9.7 Display Replacement: шаг 7, изображение 1 из 1
    • Using a plastic spudger, work around the edge of the screen, prying the screen away from the device.
  8. Samsung Galaxy Tab A 9.7 Display Replacement: шаг 8, изображение 1 из 1
    • Use the left side of the tablet as a hinge to swing the display assembly open.
    • As you move the display assembly, make sure that the display ribbon cable is unattached.
Заключение
3 участников успешно повторили данное руководство.
Jakob Gerald Schumacher
Участник с: 02/20/20
298 Репутация
Автор 3 руководств
Один комментарий
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 13
За всё время: 2,579
