Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The audio jack for the Samsung Galaxy Tab E 8.0 may not work due to internal damages or overuse. This guide shows how to replace the tablet's audio jack, which is connected to the motherboard.
Выберете то, что вам нужно
Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
Use the tweezers to flip the switch that connects the top of the strap to the motherboard.
Lift the top end of the strap with your hand and remove the strap completely from the device.
Use the tweezers to flip the switch of the connector.
Lift the connector from the motherboard.
Use the tweezers to flip the switch of the blue connector on the motherboard.
Use the tweezers to flip the switch of the connector that runs from the battery to the motherboard.
Use a JIS #00 screwdriver to remove the six 4.5mm screws at the top of the motherboard.
Lift the motherboard with your hand to detach the motherboard from the device.
Еще один человек закончил это руководство.
