Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
The front camera of the Samsung Galaxy Tab E 8.0 can be damaged if the camera is struck by a hard object. This guide shows how to replace the tablet's front camera which is attached to the motherboard.
Запчасти
Детали не указаны.
  1. Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen. Make sure the device is off and the SD card is removed before taking off the back casing.
    • Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
    • Make sure the device is off and the SD card is removed before taking off the back casing.
  2. Use the tweezers to lift the switch connecting the front camera to the motherboard. Remove the front camera from the motherboard by lifting with the tweezers. Remove the front camera from the motherboard by lifting with the tweezers.
    • Use the tweezers to lift the switch connecting the front camera to the motherboard.
    • Remove the front camera from the motherboard by lifting with the tweezers.
Заключение
2 участников успешно повторили данное руководство.
Christian Bloemhof
Участник с: 08.10.2018
943 Репутация
Автор 7 руководств
Команда
Cal Poly, Team S13-G4, White Fall 2018 Участник Cal Poly, Team S13-G4, White Fall 2018
CPSU-WHITE-F18S13G4
4 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 134
