Введение
The motherboard of the Samsung Galaxy Tab E 8.0 may malfunction after overuse of the device. This guide will show how to replace the tablet's motherboard, which is attached to the front panel.
Запчасти
Детали не указаны.
Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
Use the tweezers to lift the switch connecting the back camera to the motherboard.
Use your hand to remove the back camera from the motherboard.
Use the tweezers to lift the switch connecting the front camera to the motherboard.
Remove the front camera from the motherboard by lifting with the tweezers.
Use the tweezers to flip the switch on the bottom of the strap that goes over the battery.
Release the strap from the switch by lifting the strap with your hand.
Use the tweezers to flip the switch that connects the top of the strap to the motherboard.
Lift the top end of the strap with your hand and remove the strap completely from the device.
Use the tweezers to flip the switch of the connector.
Lift the connector from the motherboard.
Use the tweezers to flip the switch of the blue connector on the motherboard.
Use the tweezers to flip the switch of the connector that runs from the battery to the motherboard.
Use a JIS #00 screwdriver to remove the six 4.5mm screws at the top of the motherboard.
Lift the motherboard with your hand to detach the motherboard from the device.
