Введение
The camera in a phone or a tablet is easy to damage if it is dropped. So this guide highlights how to remove the back cover of the tablet in order to replace the back camera.
Запчасти
Детали не указаны.
  1. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement, Back Camera: step 1, image 1 of 1
    • Make sure the device is turned off.
    • Using the plastic opening tool, start in the center and wedge the angled tip between the plastic back and the scree.
    • Try to pressure it, wedge it back and forth.
    • Do not wedge the plastic opening tool directly on top of the power buttons and headphone buttons.
  2. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: step 2, image 1 of 2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: step 2, image 2 of 2
    • Once the bottom edge has been loosened, use the suction tool to pull it.
    • The second picture shows the internal portion of the tablet once the back cover is removed.
  3. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: step 3, image 1 of 2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: step 3, image 2 of 2
    • The first picture shows the location of back camera.
    • Disconnect the rectangular connection from the back camera to the motherboard.
  4. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: step 4, image 1 of 2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: step 4, image 2 of 2
    • The picture illustrates what the device should look like once the back camera is removed.
Заключение
Tingting Liu
Участник с: 28.09.2016
25 Репутация
1 руководство автора
Команда
USF Tampa, Team 1-4, Cagle Fall 2016 Участник USF Tampa, Team 1-4, Cagle Fall 2016
USFT-CAGLE-F16S1G4
3 членов
Автор 14 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 7
За всё время: 1,112
