Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement, Back Casing: шаг 1, изображение 1 из 1
    • Remove any micro-SD or SIM cards before continuing.
    • Verify your device is turned OFF.
    • Disconnect all external devices from your tablet.
  2. Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: шаг 2, изображение 1 из 3 Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: шаг 2, изображение 2 из 3 Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: шаг 2, изображение 3 из 3
    • Insert the plastic opening tool by wedging it between the device's screen and back cover.
    • Move the plastic tool around the edges of the device to undo the plastic lips holding the casing together.
    • This step may require more force than expected. If difficult, try using a suction cup on the screen.
  3. Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: шаг 3, изображение 1 из 3 Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: шаг 3, изображение 2 из 3 Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: шаг 3, изображение 3 из 3
    • This process will become easier as more clips are separated.
    • Use your hands to gently pull the back cover off the device after about half of the clips are separated.
    • A suction cup can be used in this step as well to assist in pulling the device apart.
  4. Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement, Front Camera: шаг 4, изображение 1 из 1
    • The front camera is located at the top, middle of the motherboard. The red rectangle in the image to the left depicts its location.
  5. Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: шаг 5, изображение 1 из 3 Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: шаг 5, изображение 2 из 3 Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: шаг 5, изображение 3 из 3
    • Remove the ribbon wires connecting the camera to the motherboard by using tweezers to flip the black latch away from the camera (towards the bottom of the tablet).
    • Carefully pull the camera out.
Заключение
William Gorham Jr
Участник с: 09/28/16
57 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 1-4, Cagle Fall 2016 Участник USF Tampa, Team 1-4, Cagle Fall 2016
USFT-CAGLE-F16S1G4
3 членов
Автор 14 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 698
