Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Back Cover: шаг 1, изображение 1 из 2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Back Cover: шаг 1, изображение 2 из 2
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: шаг 2, изображение 1 из 1
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: шаг 3, изображение 1 из 1
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Headphone Jack/Speakers Assembly: шаг 4, изображение 1 из 2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Headphone Jack/Speakers Assembly: шаг 4, изображение 2 из 2
    • Remove the two 2 mm Phillips #000 securing the headphone jack.
  5. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: шаг 5, изображение 1 из 1
    • Disconnect the blue connector by gently popping it off of the motherboard with a plastic opening tool.
  6. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: шаг 6, изображение 1 из 2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: шаг 6, изображение 2 из 2
    • Use the metal spudger to pry from the top left corner of the headphone jack/lower speaker assembly.
    • Gently lift the headphone jack/lower speaker assembly free of the device.
  7. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: шаг 7, изображение 1 из 1
    • Locate the top speaker.
    • Use a plastic opening tool to disconnect the green-gold upper speaker connector from the motherboard.
  8. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: шаг 8, изображение 1 из 2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: шаг 8, изображение 2 из 2
    • Use a spudger to pry the uper speaker up and away from the device.
Заключение
8 человек успешно провели ремонт по этому руководству.
Trent Chapman
Участник с: 10/01/15
1 384 Репутация
Автор 3 руководств
Команду
Cal Poly, Team 12-15, Maness Fall 2015 Участник Cal Poly, Team 12-15, Maness Fall 2015
CPSU-MANESS-F15S12G15
4 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 23
За последние 30 дней: 33
За всё время: 3,401
