Введение
Over time a speaker may become damaged and the audio sound quality may become poor. If this is to occur, replacing the speaker can fix this issues. This guide will show you how to replace the headphone jack and speakers.
Выберете то, что вам нужно
Place the plastic opening tool between the face of the display and rim of the back cover of the device.
Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
Remove the two 2 mm Phillips #000 securing the headphone jack.
Disconnect the blue connector by gently popping it off of the motherboard with a plastic opening tool.
Use the metal spudger to pry from the top left corner of the headphone jack/lower speaker assembly.
Gently lift the headphone jack/lower speaker assembly free of the device.
Locate the top speaker.
Use a plastic opening tool to disconnect the green-gold upper speaker connector from the motherboard.
8 участников успешно повторили данное руководство.
