Введение
If your battery does not charge consistently, or will not charge at all, your charging port may be faulty. If you are experiencing charging difficulties, the charging port may need to be replaced. This guide will show you how to do so.
Выберете то, что вам нужно
Place the plastic opening tool between the face of the display and rim of the back cover of the device.
Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
Remove the two 4 mm Phillips #000 screws securing the micro USB port.
Using the plastic opening tool, disconnect the charge port from the motherboard.
Once disconnected, lift to remove the charging port.
32 участников успешно повторили данное руководство.
6 Комментариев
What model number is this device specifically? It says WiFi, but I have the same one from a network carrier. Would this charging port work for that? Model sm-707v is the one that I have.
With these instructions I ordered part from Amazon and replaced charging port and tablet charges again. Thanks!
