Введение
Follow this guide to bring the sound back to your headphones by replacing the auxiliary port.
Выберете то, что вам нужно
Heat up an iOpener for 30 seconds and place on all four seams of the screen. A heat gun can be used as well.
The glue is now melted, so using the metal spudger shown, pry open all sides of the tablet.
When prying open near the home and touch screen buttons, use a suction cup.
This is where the auxiliary port is located.
Remove the black 3mm screw using a PH000 Phillips screwdriver.
Unclip the ribbon using the Blunt ESD Tweezer.
Lift up the auxiliary port using the Blunt ESD Tweezer.
Еще один человек закончил это руководство.
