Введение
If your home button is no longer functioning properly, it may have become worn or gotten stuck over time, this guide can help you replace it.
Выберете то, что вам нужно
Heat up an iOpener for 30 seconds and place on all four seams of the screen. A heat gun can be used as well.
The glue is now melted, so using the metal spudger shown, pry open all sides of the tablet.
When prying open near the home and touch screen buttons, use a suction cup.
Unclip the orange ribbon cable located above the battery using the Blunt ESD Tweezer.
Remove the four black 3mm screws using a PH000 Phillips screwdriver.
Using your thumb, push the home button to the right and lift up to dislodge it.
Peel the ribbon cable off carefully, it may be glued to the grey frame.
Lift the home button.
