Samsung Galaxy Tab S2 Home Button Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Tab S2 Home Button  Replacement, Screen: шаг 1, изображение 1 из 1
    • Working on your device while it is turned on may result in an electric shock. Be sure to shut down and unplug your device before you begin.
    • Removing the screen may be difficult due to strong adhesives.
    • Apply heat to all the seams of the device using an iFixit iOpener or heat gun in order to loosen the adhesive around the edges of the screen.
  2. Samsung Galaxy Tab S2 Home Button  Replacement: шаг 2, изображение 1 из 2 Samsung Galaxy Tab S2 Home Button  Replacement: шаг 2, изображение 2 из 2
    • Insert the plastic opening tool into the gap on the side of the tablet, near a corner where you want to start removing the screen.
    • Place the small suction cup on the screen near the corner that the plastic opening tool is placed.
    • Lift the small suction cup up while pushing down with the plastic opening tool to remove screen (you may need to have someone else hold the device down for proper leverage).
    • A ribbon cable is attached to the back of the screen. Avoid lifting or moving the screen more than 3-4 inches before disconnecting the ribbon cable or you could damage the device.
  3. Samsung Galaxy Tab S2 Home Button  Replacement: шаг 3, изображение 1 из 1
    • A piece of silver tape is placed over the gold ribbon cable connecting the screen to the tablet.
    • Use the tweezers to carefully remove the silver tape.
  4. Samsung Galaxy Tab S2 Home Button  Replacement: шаг 4, изображение 1 из 2 Samsung Galaxy Tab S2 Home Button  Replacement: шаг 4, изображение 2 из 2
    • With the plastic opening tool gently lift to disconnect the gold ribbon cable that attaches the screen to the base tablet.
  5. Samsung Galaxy Tab S2 Home Button  Replacement, Panel Replacement: шаг 5, изображение 1 из 2 Samsung Galaxy Tab S2 Home Button  Replacement, Panel Replacement: шаг 5, изображение 2 из 2
    • Remove the nineteen 3mm Phillips #1 screws.
  6. Samsung Galaxy Tab S2 Home Button  Replacement: шаг 6, изображение 1 из 2 Samsung Galaxy Tab S2 Home Button  Replacement: шаг 6, изображение 2 из 2
    • Pry open the next layer of the device using the plastic opening tool.
    • Even though the device separates along the outside edge, using the inside edge (as pictured) may help with leverage.
  7. Samsung Galaxy Tab S2 Home Button  Replacement, Battery: шаг 7, изображение 1 из 2 Samsung Galaxy Tab S2 Home Button  Replacement, Battery: шаг 7, изображение 2 из 2
    • Remove the four black 3 mm Phillips #1 screws that hold the battery in place.
  8. Samsung Galaxy Tab S2 Home Button  Replacement: шаг 8, изображение 1 из 1
    • Use a plastic opening tool to lift the black flap on the ZIF connector located in the top left corner of the device.
    • Once the connector is unlocked, pull the ribbon cable out with tweezers.
    • This cable does not need to be completely removed, only one side is enough to allow the battery to be taken out.
  9. Samsung Galaxy Tab S2 Home Button  Replacement: шаг 9, изображение 1 из 2 Samsung Galaxy Tab S2 Home Button  Replacement: шаг 9, изображение 2 из 2
    • Using the plastic opening tool remove the cable that connects the battery to the device.
    • Now you can remove the battery with your hands.
  10. Samsung Galaxy Tab S2 Home Button  Replacement, Home Button: шаг 10, изображение 1 из 1
    • Using the plastic opening device detach the rear connector of the home button from the device.
  11. Samsung Galaxy Tab S2 Home Button  Replacement: шаг 11, изображение 1 из 1
    • Flip the device open and gently pry the home button out using the plastic opening device.
  12. Samsung Galaxy Tab S2 Home Button  Replacement: шаг 12, изображение 1 из 1
    • Gently remove the home button by pulling it straight up.
Заключение
2 участников успешно повторили данное руководство.
Jovina Martinez
Участник с: 01/20/16
2 049 Репутация
Автор 7 руководств
Команда
USF Tampa, Team 10-4, Remmell Spring 2016 Участник USF Tampa, Team 10-4, Remmell Spring 2016
USFT-REMMELL-S16S10G4
4 членов
Автор 18 руководств
2 Комментариев
Nice writeup, but I can't seem to find where to buy the home button. Anyone know?
Josh Keener - Ответить
Mais, où acheter le bouton????
rejeannelepage - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 9
За последние 30 дней: 52
За всё время: 7,224
