Введение
If your home button is sticking, or not working you may need to replace it.
Запчасти
Детали не указаны.
Apply heat to all the seams of the device using an iFixit iOpener or heat gun in order to loosen the adhesive around the edges of the screen.
Insert the plastic opening tool into the gap on the side of the tablet, near a corner where you want to start removing the screen.
Place the small suction cup on the screen near the corner that the plastic opening tool is placed.
Lift the small suction cup up while pushing down with the plastic opening tool to remove screen (you may need to have someone else hold the device down for proper leverage).
With the plastic opening tool gently lift to disconnect the gold ribbon cable that attaches the screen to the base tablet.
Remove the four black 3 mm Phillips #1 screws that hold the battery in place.
Use a plastic opening tool to lift the black flap on the ZIF connector located in the top left corner of the device.
Once the connector is unlocked, pull the ribbon cable out with tweezers.
Using the plastic opening tool remove the cable that connects the battery to the device.
Now you can remove the battery with your hands.
Using the plastic opening device detach the rear connector of the home button from the device.
Flip the device open and gently pry the home button out using the plastic opening device.
2 участников успешно повторили данное руководство.
Один комментарий
Nice writeup, but I can't seem to find where to buy the home button. Anyone know?
