Введение
If your home button is sticking, or not working you may need to replace it.
Выберете то, что вам нужно
Apply heat to all the seams of the device using an iFixit iOpener or heat gun in order to loosen the adhesive around the edges of the screen.
Insert the plastic opening tool into the gap on the side of the tablet, near a corner where you want to start removing the screen.
Place the small suction cup on the screen near the corner that the plastic opening tool is placed.
Lift the small suction cup up while pushing down with the plastic opening tool to remove screen (you may need to have someone else hold the device down for proper leverage).
The lower portion of the screen is glued to the body. The screen is unable to be completely removed.
starte oben, unten verhindert eine Nase an dem Audioanschluß das erste anheben.
start upside, downside a nose at the audio connector prevents the first lifting.
Difficile, j'ai acheté les outils nécessaires. Après avoir chauffé les côtés et essayé de les décoller, la vitre a craqué.😠
Had to use a heat gun to remove with patience and time, using a pic to "saw" into the seal, starting with the right side corners. Stopping every few seconds to reheat with heat gun. Take care on the bottom left corner, and left side. There is very little room between the edge and LCD, making it easy to stick a plastic pick or removal tool in between the LCD and front glass. The other sides have more room for prying. I nicked the bottom left corner with a prying pic, which killed the entire display :-( Good luck!
Use the tweezers to carefully remove the silver tape.
With the plastic opening tool gently lift to disconnect the gold ribbon cable that attaches the screen to the base tablet.
Remove the nineteen 3mm Phillips #1 screws.
make sure to remove the 2 black screws on the frame. i fix it doesnt say to take those off. nearly damaged the frame
Pry open the next layer of the device using the plastic opening tool.
-Zuvor unbedingt SIM Karte u microSD entfernen, sonst bleibt der Elekronikpart am Gehäuse fest und das Flachbandkabel davon kann beschädigt werden!
-Lösen des unteren Teils des Innengehäuses zum Schluss, da Ladebuchse eine Nase hat und sich erst löst wenn man es schräg nach unten abhebt.
Remove the four black 3 mm Phillips #1 screws that hold the battery in place.
I had an issue with charging of Tab S2. When you connect it to a charger, it detects it, charges for 2 seconds, stops charging for 7-8 seconds and charges again for 2 seconds. It keeps going on in circles. It actually did charge to 100%, but it could take a whole day. I watched some videos online and there’s a way to get to it from behind. I got myself tools and a new battery, thinking it could be a battery problem. Long story short, there are flat cables reaching behind from volume buttons glued to the back cover and they use pressure from the back cover to make contact. Of course, I broke the flat cable. Most of the back cover is held in place by clips, but right next to the round metal looking “buttons” there is some extra strong glue (north of those “buttons”). Samsung didn’t want to make repairs easy and simple :/.
Use a plastic opening tool to lift the black flap on the ZIF connector located in the top left corner of the device.
Once the connector is unlocked, pull the ribbon cable out with tweezers.
I did not find it necessary to detach this cable. The battery slid out from under it easily.
Using the plastic opening tool remove the cable that connects the battery to the device.
Now you can remove the battery with your hands.
I was proud of myself. It was for me as easy as this, videos online showed more difficulty . The suction cup and the jimmy was enough to open the screen. Do watch some videos online to see all the parts you could damage and on how to open the different cable connectors as they are and work different.
Using the plastic opening device detach the rear connector of the home button from the device.
Flip the device open and gently pry the home button out using the plastic opening device.
2 участников успешно повторили данное руководство.
2 Комментариев
Nice writeup, but I can't seem to find where to buy the home button. Anyone know?
Mais, où acheter le bouton????
m.E. wichtig vorher die Kartenhalter für SIM und SD entfernen, sonst löst sich der Kontakt unkontrolliert bei Schritt 6.
Frank Huebner - Ответить
You make no mention of re-Glueing the screen, just applying the steps in reverse order - does that mean simply applying heat again will re-glue the components from the residue?
Robin Penny - Ответить
i replaced the battery, the sticky tape did hold up again, but if you replace the screen it depends on whate side the tape sticks to. On ine the most part of the tape stuck to the screen.
Steffen Hahn -
I know its 2020 but i cracked my screen and idk if its on or not
benjamin burkowski_FaZe - Ответить
