Введение
Prerequisite Only.
Запчасти
Детали не указаны.
  1. Working on your device while it is turned on may result in an electric shock. Be sure to shut down and unplug your device before you begin.
    • Working on your device while it is turned on may result in an electric shock. Be sure to shut down and unplug your device before you begin.
    • Removing the screen may be difficult due to strong adhesives.
    • Apply heat to all the seams of the device using an iFixit iOpener or heat gun in order to loosen the adhesive around the edges of the screen.
  2. Insert the plastic opening tool into the gap on the side of the tablet, near a corner where you want to start removing the screen. Place the small suction cup on the screen near the corner that the plastic opening tool is placed.
    • Insert the plastic opening tool into the gap on the side of the tablet, near a corner where you want to start removing the screen.
    • Place the small suction cup on the screen near the corner that the plastic opening tool is placed.
    • Lift the small suction cup up while pushing down with the plastic opening tool to remove screen (you may need to have someone else hold the device down for proper leverage).
    • A ribbon cable is attached to the back of the screen. Avoid lifting or moving the screen more than 3-4 inches before disconnecting the ribbon cable or you could damage the device.
  3. A piece of silver tape is placed over the gold ribbon cable connecting the screen to the tablet.
    • A piece of silver tape is placed over the gold ribbon cable connecting the screen to the tablet.
    • Use the tweezers to carefully remove the silver tape.
  4. With the plastic opening tool gently lift to disconnect the gold ribbon cable  that attaches the screen to the base tablet. With the plastic opening tool gently lift to disconnect the gold ribbon cable  that attaches the screen to the base tablet.
    • With the plastic opening tool gently lift to disconnect the gold ribbon cable that attaches the screen to the base tablet.
  5. Remove the nineteen 3mm Phillips #1 screws. Remove the nineteen 3mm Phillips #1 screws.
    • Remove the nineteen 3mm Phillips #1 screws.
  6. Pry open the next layer of the device using the plastic opening tool. Even though the device separates along the outside edge, using the inside edge (as pictured) may help with leverage.
    • Pry open the next layer of the device using the plastic opening tool.
    • Even though the device separates along the outside edge, using the inside edge (as pictured) may help with leverage.
Заключение
Jovina Martinez
Участник с: 20.01.2016
1 903 Репутация
Автор 7 руководств
Команда
USF Tampa, Team 10-4, Remmell Spring 2016 Участник USF Tampa, Team 10-4, Remmell Spring 2016
USFT-REMMELL-S16S10G4
4 членов
Автор 18 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 317
