Samsung Galaxy Tab S3 Display Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Tab S3 Display Replacement, Display: шаг 1, изображение 1 из 1
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Samsung Galaxy Tab S3 Display Replacement: шаг 2, изображение 1 из 1
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
  3. Samsung Galaxy Tab S3 Display Replacement: шаг 3, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Plastic Cards
    $2.99
    Купить
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
  4. Samsung Galaxy Tab S3 Display Replacement: шаг 4, изображение 1 из 3 Samsung Galaxy Tab S3 Display Replacement: шаг 4, изображение 2 из 3 Samsung Galaxy Tab S3 Display Replacement: шаг 4, изображение 3 из 3
    • Pull off the glass panel using the suction cup.
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  5. Samsung Galaxy Tab S3 Display Replacement, Rear glass panel: шаг 5, изображение 1 из 2 Samsung Galaxy Tab S3 Display Replacement, Rear glass panel: шаг 5, изображение 2 из 2
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
Заключение
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, you may need to apply more during the reassembly process.
7 участников успешно повторили данное руководство.
Jelly Romero
Участник с: 04/19/18
322 Репутация
1 руководство автора
Команда
Cal Poly, Team S22-G4, Maness Spring 2018 Участник Cal Poly, Team S22-G4, Maness Spring 2018
CPSU-MANESS-S18S22G4
5 членов
Автор 15 руководств
5 Комментариев
Thank you so much, It helped me so much.
MRxROBOT - Ответить
What if the digitizer is ok and only the glass cover is cracked
stargazer_jbl - Ответить
if you need more adhesive what is the right type to buy? Want to have some on hand before I open my S3 up.
jnorr - Ответить
If my screen freezing exactly half, can that be the connection cable damaged.? It's look like it happens every time I touch or hold the corner where the volume and power buttons are. Never dropped it.
Lena Clark - Ответить
I also have the same issue
How your issue was resolved.
Ashwin -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 36
За последние 30 дней: 168
За всё время: 26,526
