Введение
For the Samsung Galaxy TabPro S, model SM-W700NZKAXAR, it is important for the front-facing camera to be functional and not broken. The front-facing camera allows to take pictures with the front side of the tablet. Thus, the ability to capture real-time memories is lost without the front-facing camera.
Выберете то, что вам нужно
Remove the back of the tablet by prying the plastic back using a flat tool.
When the tool has been inserted under the back, slide it all the way around the tablet to fully unclip it.
Once the back has been removed, disconnect all cables using a pair of tweezers to avoid damaging any components.
Once the cables have been disconnected, remove the battery using a flat plastic tool (not the metal spudger).
Use a Phillips #0 screwdriver to remove the screws that secure the motherboard.
Remove the metal plate once the screws are gone and the motherboard will be ready to be replaced.
Remove motherboard by prying it up with a flat plastic opening tool (not metal spudger).
Be sure that all components have been disconnected beforehand, especially the front-facing camera (located above the motherboard in the top center of the frame).
Once the camera has been disconnected from the motherboard, it can be removed using a pair of pliers.
