Введение
For the Samsung Galaxy TabPro S, model SM-W700NZKAXAR. The motherboard is essential part for any device so other parts in the device function properly. Any device should have a motherboard working properly, so for this guides will help the user to replace the motherboard safely.
Выберете то, что вам нужно
Place the tablet on it's back.
Open the back cover by sliding an opening tool and then clicking the back cover open.
Use a tweezer to disconnect the cables from the battery.
The battery can be gently removed now.
Now, you have removed the screws, wires, and battery.
Next, you slide a plastic spudger under the motherboard.
Then, slide the motherboard out gently.
