Samsung Galaxy Watch Active2 Screen Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Watch Active2 Screen Replacement, Turn off the watch: шаг 1, изображение 1 из 2 Samsung Galaxy Watch Active2 Screen Replacement, Turn off the watch: шаг 1, изображение 2 из 2
    • Turn off the Galaxy Watch Active2 by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears, tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Samsung Galaxy Watch Active2 Screen Replacement, Remove the rear screws: шаг 2, изображение 1 из 1
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Samsung Galaxy Watch Active2 Screen Replacement, Separate the back cover from the housing: шаг 3, изображение 1 из 3 Samsung Galaxy Watch Active2 Screen Replacement, Separate the back cover from the housing: шаг 3, изображение 2 из 3 Samsung Galaxy Watch Active2 Screen Replacement, Separate the back cover from the housing: шаг 3, изображение 3 из 3
    • Use an opening pick and place it between the plastic back cover and the metal housing near the buttons.
    • Push the opening pick into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the sensor array: шаг 4, изображение 1 из 2 Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the sensor array: шаг 4, изображение 2 из 2
    • Carefully lift the back cover to access the sensor array connector.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Samsung Galaxy Watch Active2 Screen Replacement, Remove the back cover: шаг 5, изображение 1 из 1
    • Remove the back cover.
  6. Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the display and speaker: шаг 6, изображение 1 из 3 Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the display and speaker: шаг 6, изображение 2 из 3 Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the display and speaker: шаг 6, изображение 3 из 3
    • Use a spudger to disconnect the display assembly and the speaker.
  7. Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the barometric sensor, buttons, and mic: шаг 7, изображение 1 из 3 Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the barometric sensor, buttons, and mic: шаг 7, изображение 2 из 3 Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the barometric sensor, buttons, and mic: шаг 7, изображение 3 из 3
    • Use a spudger to disconnect the barometric sensor, the buttons, and the microphone.
  8. Samsung Galaxy Watch Active2 Screen Replacement, Lift the core assembly: шаг 8, изображение 1 из 2 Samsung Galaxy Watch Active2 Screen Replacement, Lift the core assembly: шаг 8, изображение 2 из 2
    • Place a spudger underneath the motherboard at the top right next to the display connector.
    • Slightly twist and lever the spudger to loosen the core assembly.
    • It might help to also check the comments below this and the next step if you’re having difficulties.
  9. Samsung Galaxy Watch Active2 Screen Replacement, Remove the core assembly: шаг 9, изображение 1 из 3 Samsung Galaxy Watch Active2 Screen Replacement, Remove the core assembly: шаг 9, изображение 2 из 3 Samsung Galaxy Watch Active2 Screen Replacement, Remove the core assembly: шаг 9, изображение 3 из 3
    • Grab the core assembly and carefully slide it out from under the cables.
    • Remove the core assembly.
  10. Samsung Galaxy Watch Active2 Screen Replacement, Loosen the display: шаг 10, изображение 1 из 3 Samsung Galaxy Watch Active2 Screen Replacement, Loosen the display: шаг 10, изображение 2 из 3 Samsung Galaxy Watch Active2 Screen Replacement, Loosen the display: шаг 10, изображение 3 из 3
    • Place the edge of an opening tool under the speaker unit.
    • Lever the opening tool down to separate the display from the frame.
  11. Samsung Galaxy Watch Active2 Screen Replacement, Remove the frame: шаг 11, изображение 1 из 2 Samsung Galaxy Watch Active2 Screen Replacement, Remove the frame: шаг 11, изображение 2 из 2
    • Remove the frame from the display.
    • Make sure to remove any remaining adhesive from the frame with isopropyl alcohol (>90%) before applying the adhesive or installing the new display.
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%). You may need to remove adhesive backings from the new part before installing.
18 участников успешно повторили данное руководство.
Tobias Isakeit
Участник с: 03/31/14
112 962 Репутация
Автор 188 руководств
Команда
iFixit Участник iFixit
Community
136 членов
Автор 15 194 руководств
15 Комментариев
Does anyone know where to buy the replacement screen for Active 2? Or what keywords should I search for (SKU or model)?
Angelo Sembrano - Ответить
SM-R830 for the 40mm version, SM-R820 for the 44mm one. People on ebay resell them but they cost upwards of $100. I’d look into broken watches of the same type that maybe the battery is dead and they’re selling it for cheap, then do a swap job on the (hopefully) working screen.
Justin Collins -
Seconding the question on where to buy a replacement screen
Arjun Ramakrishnan - Ответить
You could be lucky on rounded.com
Tobias Isakeit - Ответить
What adhesive would be best to use?
Kelsey Crank - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 75
За последние 7 дней: 554
За последние 30 дней: 2,698
За всё время: 70,334
