Введение
Use this guide to replace a cracked or broken screen on your Galaxy Watch.
  1. Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
    • Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
  2. Use an opening tool to get between the back cover and the metal housing of the watch. Carefully pry the plastic back cover open.
    • Use an opening tool to get between the back cover and the metal housing of the watch.
    • Carefully pry the plastic back cover open.
    • Don't remove the back cover yet. There is a flex cable running to the core assembly inside.
  3. Lay down the watch and lift the back cover to access the sensor connector on the motherboard. Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
    • Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
  4. Use a spudger to disconnect the sensor flex cable from the motherboard. Use a spudger to disconnect the sensor flex cable from the motherboard.
    • Use a spudger to disconnect the sensor flex cable from the motherboard.
  5. Remove the back cover. When closing the watch make sure the rubber gasket is undamaged or replace it with a new one. When closing the watch make sure the rubber gasket is undamaged or replace it with a new one.
    • Remove the back cover.
    • When closing the watch make sure the rubber gasket is undamaged or replace it with a new one.
  6. Use a spudger to disconnect the display flex cable from the motherboard. Use a spudger to disconnect the display flex cable from the motherboard.
    • Use a spudger to disconnect the display flex cable from the motherboard.
  7. Lift the core unit out of the housing. The core's plastic frame sits tight inside the housing.
    • Lift the core unit out of the housing.
    • The core's plastic frame sits tight inside the housing.
    • Carefully thread the display flex cable through the gap of the core's plastic frame.
  8. If necessary apply some tape over the display to avoid any injury from glass shards.
    • If necessary apply some tape over the display to avoid any injury from glass shards.
  9. Use your finger or thumb to steadily push down on the display to loosen the adhesive. Heating the display with a hair dryer or iOpener helps softening the adhesive.
    • Use your finger or thumb to steadily push down on the display to loosen the adhesive.
    • Heating the display with a hair dryer or iOpener helps softening the adhesive.
    • Remove the display.
Заключение
5 участников успешно повторили данное руководство.
Tobias Isakeit
Участник с: 31.03.2014
92 698 Репутация
Автор 174 руководств
Команда
iFixit Участник iFixit
Community
139 членов
Автор 15 641 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 27
За последние 7 дней: 215
За последние 30 дней: 848
За всё время: 12,876
