Samsung Gear 2 Neo Speaker Replacement
Выберете то, что вам нужно
  1. Samsung Gear 2 Neo Speaker Replacement, Battery: шаг 1, изображение 1 из 1
    • Remove the wristband by sliding the metal pins located on both sides of the wrist band, and pulling the wristband off.
  2. Samsung Gear 2 Neo Speaker Replacement: шаг 2, изображение 1 из 2 Samsung Gear 2 Neo Speaker Replacement: шаг 2, изображение 2 из 2
    • Use a T5 Torx Screwdriver to remove the 4 (0.4 mm) screws located on the back of the watch.
  3. Samsung Gear 2 Neo Speaker Replacement: шаг 3, изображение 1 из 1
    • Slide the opening tool in between the two halves of the case and slide along the edge of the watch while gently prying the back cover away from the face of the watch.
  4. Samsung Gear 2 Neo Speaker Replacement: шаг 4, изображение 1 из 2 Samsung Gear 2 Neo Speaker Replacement: шаг 4, изображение 2 из 2
    • Use a pair of tweezers to peel the battery ribbon cable off of the back cover.
    • Avoid damaging the gold terminals on the ribbon cable.
    • When reassembling, make sure that the yellow strip snaps back on to the black pin.
    • The pin is located, and marked on the picture.
    • Pull up on the tab that says, “Pull”, the battery will lift straight out.
  5. Samsung Gear 2 Neo Speaker Replacement, Speaker: шаг 5, изображение 1 из 1
    • Use a pair of tweezers to remove the rubber gasket. It should come off with ease.
  6. Samsung Gear 2 Neo Speaker Replacement: шаг 6, изображение 1 из 1
    • Using the fine tweezers, pull up on the speaker ribbon cable until separated from the back cover. Make sure to approach it like in the picture otherwise it may not come off cleanly.
    • To lift out the speaker, place the tweezers underneath the speaker at the top left corner of the speaker and pry it up.
Заключение
Victor Yore
Участник с: 08/27/15
705 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 5-6, Blackwell Fall 2015 Участник USF Tampa, Team 5-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G6
3 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 989
