Введение
This guide will walk you through the process of replacing a broken or defective speaker in a Samsung Gear 2.
Выберете то, что вам нужно
To remove each strap, locate the metal latches on both sides of the back of the Gear.
Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
Pry the device open from the other side also if it does not fully disassemble from one side.
Use the pointed side of the spudger to remove the small, orange battery cable.
Use tweezers to carefully grab the connector.
Gently pull upwards to detach it from the case and from the adhesive.
4 участников успешно повторили данное руководство.
3 Комментариев
what happens if I don't put the speakers back?
Where can I buy the speaker?
