Введение
This guide will show you how to remove the rear camera module from the Samsung Gear 360. Like the front camera, this module can be removed by completing a tear-down of the device, and unscrewing the module from there.
Выберете то, что вам нужно
Insert a small flathead screwdriver into marked slot on camera lens and pry off camera lens cover.
Using a PH00 screwdriver head, remove all Phillips #00 0.75 mm screws on the front of the camera.
Repeat for the back side of the camera.
Peel off the black rubber located on the bottom of the device using your hand or a small flathead screwdriver.
Once the black rubber has been removed, unscrew all Phillips #00 0.75 mm screws on the bottom of the device using a PH00 screwdriver head.
To remove the left cover of the camera body, lift the left cover using a small flathead screwdriver and pull it off.
Once the camera body has been removed, lift and pull off the metal support ring using a small flathead screwdriver.
Repeat for both sides of the camera.
Remove all Phillips #00 0.75 mm screws from the body of the camera using a PH00 screwdriver head.
Carefully lift the three sensors off using a plastic opening tool and pull them aside.
Carefully use a plastic opening tool to separate the gray case from the black case on the device.
Insert a plastic removal tool underneath the four sensors on the motherboard to fully separate the camera case.
Within the grey half of the case, unscrew both Phillips #00 0.75 mm screws located on the metal plate using PH00 screwdriver.
Using a PH000 screwdriver head, remove the both Phillips #000 0.75 mm screws on the grey case.
Using a plastic opening tool, remove the plastic cover underneath the rear camera
Gently remove the rear camera module by using a plastic opening tool and lifting the module.
2 участников успешно повторили данное руководство.
