Введение
Use this guide to remove the speaker from the Samsung Gear 360. You will need to complete an almost full tear-down of the device to get to the speaker, but you can safely remove it after separating the two cases.
Выберете то, что вам нужно
Insert a small flathead screwdriver into marked slot on camera lens and pry off camera lens cover.
Using a PH00 screwdriver head, remove all Phillips #00 0.75 mm screws on the front of the camera.
Repeat for the back side of the camera.
Peel off the black rubber located on the bottom of the device using your hand or a small flathead screwdriver.
Once the black rubber has been removed, unscrew all Phillips #00 0.75 mm screws on the bottom of the device using a PH00 screwdriver head.
To remove the left cover of the camera body, lift the left cover using a small flathead screwdriver and pull it off.
Once the camera body has been removed, lift and pull off the metal support ring using a small flathead screwdriver.
Repeat for both sides of the camera.
Remove all Phillips #00 0.75 mm screws from the body of the camera using a PH00 screwdriver head.
Carefully lift the three sensors off using a plastic opening tool and pull them aside.
Carefully use a plastic opening tool to separate the gray case from the black case on the device.
Insert a plastic removal tool underneath the four sensors on the motherboard to fully separate the camera case.
Within gold metal half of the case, unscrew the Phillips #00 0.75 mm screw located on the metal plate using a PH00 screwdriver.
Using a plastic opening tool, remove the metal cover.
Using a PH000 screwdriver head, unscrew all Phillips #00 0.75 mm screws.
To remove the speaker from the device, use a plastic opening tool on the edge and gently lift it up.
