Введение
This guide will give step by step instructions on how to replace the battery and motherboard.
Выберете то, что вам нужно
Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
Once the motherboard and the battery are removed, disconnect the battery at the connector.
Use a spudger to gently pry upward on the clasp connecting the battery to the motherboard.
36 участников успешно повторили данное руководство.
16 Комментариев
Apparently you can get them in Spain.
