Введение
This guide shows how to remove the display of the watch from the rest of the watch.
Выберете то, что вам нужно
Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
To reassemble your device, follow these instructions in reverse order. You will need an adhesive to connect the screen back to the rest of the watch.
19 участников успешно повторили данное руководство.
16 Комментариев
Where can i get the LCD for Gear S
Hi my gear is showing the watch face setting then glitches to the photo setting and is not allowing me to use any other apps?
My watch is doing the same thing. Did you get a fix for it?
