Введение
This guide will give step by step instructions on how to replace the home button.
Выберете то, что вам нужно
Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
Locate the home ribbon connector attached to the wrist side (side that faces the user when wearing it) of the motherboard assembly.
Locate the home ribbon assembly attached to the screen side of the motherboard assembly.
2 участников успешно повторили данное руководство.
2 Комментариев
where can i buy the home buton?
I am in search of the SM-R750v Housing Back Cover, any suggestions
